#1StunnaVic;896568 said:
i've suddenly become very confused..... so from what im understanding the dm ps line is not too short because it shoots straight from the ps pump (on the driverside) to the rack where the old 7m high pressure line used to be (which is also on the driverside.) now if this is correct then i have another question..... on the passenger side of the rack i have 3 lines for the powersteering which i have to account for, 2 are from the old 7m ps cooler, i have the 1j ps cooler to replace the old 7m ps cooler. the 1j ps cooler will have an opening on the driverside going to the ps reservior and an opening on the passenger side to go to a ps line which i assume is leading to the rack. i can account for these 2 lines but there is a 3rd line on the passenger side for the powersteering with a banjo fitting on it. i thought this line runs to the rack connecting on the passenger side and the dm ps line was suppose to thread into it on the passenger side. thats y when i got my dm line ithought it was too short... what is this line then with the banjo fitting on it on the passenger side and what do i do with it??? i could swear that this line connects to the rack on the passenger side. but im starting to think that i saw wrong... only thing that would make sense to me is what i saw wasnt the line connected to the rack but simply anchored there with a screw ( like how the 1j ps line is anchored to the bottom of the block) to keep it from moving around and the line just ran back to the driver side of the car.
ahhh!!! im so confused!!! im gonna stop writing now this post is getting too long and i dont wanna confuse anyone else with it.
2 of the lines are for the cooler one should run right to the other, remove these.
the other line goes right to where i was talking about remove that to the point you stick the line on.
the high pressure line connects to the pump (no banjo involed it replaces it) and goes to the rack where there is also no banjo involved anymore
then you take the resovoir mount it somewhere near the pump and connect a 1 inch or so low pressure line from it to the resovoir and the smaller low pressure line connects from the resovoir to whatever cooler you choose and back to the rack
