Power antenna , took the thing appart
Gunnar
116
Belgium
www.chiptuners.org
Ok, so the kids were trying to pull on the thing when i was shutting off the car.
After that it wouldn't go up anymore :)
So i went about removing the side of the spoiler, the inside panneling and got to the antenna and pulled it inside to the trunk area.
It's not like the guide on the cygnus site, mine has a black plastic cover and inside is not a nylone round cable, but one with toothed side that slides next to some gears to go into the antenna rod.
I called toyota and they can't seem to get that part. So am i looking at an antenna from a different car or an aftermarket replacement?
Supra469
495
Maryland
I faced the same delimma as you and decided to just get a new one rather than try to fix this older one. New one works great!
8,898
I haven't had to change one on my any of my Supras. But all the Toyota's I did at the dealer used the plastic cable inside the antenna mast with teeth wrapped around the gear.
You can get a new mast, they might even be interchangable. The mast can come seperate from the antenna assembly.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Mine was busted off when I got the car. Does anyone know if those ebay ones are "drop-in" or is it better to get one from Toyota?
8,898
In terms of fitment, you know I always favor the dealer. Not to be confused with most of you wanting to increase engine output.
I have ordered from Champion/Jay Marks. I like their website.
Muzy
182
Alberta
I have been looking as well. We offer one in our napa store. Pics and specs look good
I'll order it after lunch will have it on tuesday. I'm post a pic and inculde my observations
as well if you like. Don't know the part # of the top off my head but could post that in
about a hour from now. muzy
Muzy
182
Alberta
Napa part # 730-4832-black mast 86.5-98,
# 730-4834-chrome mast 86.5-98
Hope that helps. muzy
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
This particular power antenna unit uses this very odd type of clutch inside. It has two metal washers and a carbon disc sandwiched between. My antenna wasnt 100% perfectly strait or had some kind of a pinch in it somewhere so only sometimes it would go up allt he way (the clutch would slip before it pushed the antenna up more). I tried everything to make the clutch grip harder including sanding but nothing worked. Besides, the motor is very loud and annoying, so i just disconnected it.
Muzy
182
Alberta
What antenna are you refering too? muzy
CajunKenny
Nov 15, 2007
3,255
Washington
jetjock;1196986 said:
I leave mine down (disconnected it years ago) and use the diversity one instead. Works fine in urban areas. CDs or MP3 when in the boonies...
Excuse the ignorance here jetjock; but, what is the 'diversity' one? I noticed recently that my car has two antenna plugs to go into the back of a radio. Do the supras have two antennas?!
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks...
Currently, my reception is horrible. I'll switch to the other antenna and see if there is an improvement.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
You'll need to pick up an antenna adapter to use the other one, any decent stereo installation place will have them. The second antenna jack is the weird mini plug, not the standard size that everything else uses.
I just switched back to the powered one today, we'll see how long that lasts. :)
Muzy
182
Alberta
Hey Gunnar, will grab one tommorow and do a quicj instale and see whats up. Snap a couple pics to.
As far as what CyFi6 was saying I would imagine he was referring to the after market one
I discribed. As far as if not working right and being noisie it was bent, so hope that's not
how they come. muzy
Muzy
182
Alberta
GrimJack;1197660 said:
Well, you can get them from Toyota for ~$25. Part number 86336-14350 or 86336-14370.
Say is that the whole motor and mast assembly, or just the mast? muzy:icon_surp
Muzy
182
Alberta
GrimJack;1197672 said:
Just the mast, of course. :) The entire assembly is ~$235, part numbers for it are 86300-14362 or 86300-14372.
LOL, of course. How could i be so ridiculous.:3d_frown:
Any way, looks like this is the route foe you Gunnar as OEM parts are just
the most sensable thing to do.:icon_bigg muzy
Nice work GrimJack
