Okay, regardless of what season it is, when I turn the key to the "START" position. Every once in a while it will be a short 5 second or so delay before it starts the car. However, there is no problem suggesting alternator, or battery, and when it does start up it starts up really smooth like it should. I'm being told it could be the Ignition Switch, but also remember reading something about a 30 Amp Relay Mod, and wondered if that had any bearing on the problem I'm receiving, or if that was something totally different? Now the only thing I haven't replaced yet is the Starter and the Ignition Switch. Both run around 50 or so dollars at my local Advanced Auto store, of which I have a commercial account with and probably get both for $65. Any thoughts would be well appreciated as usual.
Zer0
Zer0
