Well, drove from Ft. Bragg to Raleigh last nite to see the import show. Very nice.
Yet, for some reason while going down a rough part of highway 40, my car just dies while I am going 85 mph in 5th gear.
Why in the world would it just die in gear? How is that possible? I thought that while the car was in gear... the engine would keep going. It shouldn't just die.
Anyhow, tried to turn the engine with the starter... nothing. Then I tried stepping on the clutch and dropped it a couple of times and the car started up and went.
Yet, when going through downtown, rough roads, IT HAPPEN AGAIN! I do the same trick as before and it works.
Then right before getting into the car show, semi-smooth roads... IT HAPPENS AGAIN!
I am freaked out now... it's an hour and 30 minute drive back to base.
So I go 5-10 miles slower than the speed limit home.... rough road... the car dies in gear, but I drop the clutch a couple of times and it goes.
Then We stop at a gas station had to get drinks and all... turn the car off... and... when backing out of the parking sport, car shudders really hard (darn new stage 3 clutch) and then dies. It wouldn't start at all. CRAP!
We put gas in it, with the hope the gas guage might just be jacked up... nope. The my friend is like, "lets push start it."
We push start it, but it doesn't start... then I try to start it with the ignition... and it finally worked.
I've tried reading as much as I can about this problem, just frustrated. No CEL, but I will check codes tomorrow. I seriously cannot figure what it could be.
Everything turns on. All the start up lights come on, engine turns, fuel is there, just changed spark plugs and coil packs... what could it be?
