Good morning everyone,
I've run into some issues over the last few weeks, and I keep thinking BHG in my mind after reading as much as I can find about my troubles.
Symptoms
- Losing coolant, warmer temps than normal (Replaced bad hose off rear of block, now thinking it sprung a leak due to excessive pressure)
- Losing coolant through the overflow.
- I get pressure in the hoses after about 20 mins and the car warms up.
- If I leave the cap off, when it warms up I get bubbles in the radiator.
I pulled the thermostat housing and heard it spring snap closed (there's one issue) Now. Could having a stuck open thermostat cause my symptoms? Possibly hot enough that the coolant was boiling and building pressure enough to push out the overflow. Or, do I have a BHG when it warms up that it starts pushing air though the cooling system.
Now, here are a couple other things:
- No coolant sticking to the dipstick, nothing under the cap that makes me think that coolant is getting into the oil.
- No white smoke out of the exhaust.
I have not been driving the car since I noticed it getting warm for fear of doing any more damage.
I'm replacing the thermostat today.
The shop around the corner did a pressure test to the cooling, but did not see any leaks anywhere. I'm open to suggestions at this point right now. The only mods to car are just a downpipe, and intake. Everything else is stock.
Thanks,
Joe
Symptoms
Thanks,
Joe
