My Koyo Race Radiator started leaking the other day really bad, it got hot twice but not fully to the red line... As soon as I saw it start to creep up I pulled over and put some more water in it... I temp fixed the radiator with some of the liquid aluminum puddy... it's not leaking anymore and the car didn't leak on a trip.. it did blow a little water out of the resivoir though, I did fill it up to the top... I did a couple of 2nd gear 19psi pulls too... still holding water and making a ton of power... Now the thing is I changed my oil yesterday and the oil looked fine and the water looked fine, just the cap has some weird white gunk underneath it, my first thought was bhg... I checked the plugs and they are all fine and the pistons look normal not super clean like a bhg would do.. going to do a compression test in a little bit and see if it is ok as well..
My catch can pipe did pop off the other day and I ran like that for 2 days before I changed my oil... Could that have caused the residue? Also with the temps fluctuating here with the snow and everything I was also told that might cause it too..
Thanks guys in advance for the input...
BTW I have a Titan MHG w/arps at 85lbs... only 15k miles on the rebuild...
Now my turbo is smoking pretty bad too.. it is going to get rebuilt next week along with getting a new mishimoto radiator...
