Port matching?
radiod
1,342
Abbotsford, BC
Don't quote me on this, but I'm pretty sure on the exhaust side, you want the ports to be slightly smaller than the manifold diameter so the exhaust gases can expand as they travel out of the head.
It's so it acts as a reversion dam.
spooln30
milwaukee,WI
I always port match the intake manis to the head. You can open the intake ports, you just don't want them to be super smooth so the full and air can mix better before they enter the cylinder.
radiod
1,342
Abbotsford, BC
That would make sense. Best to keep the flow going towards the turbo than having it try and make it's way back in to the engine ;). For those that might be confused still, I'll lay down an IJ quote from another thread I found...
IJ.;1618591 said:
Think of it as a non return valve for the exhaust port, if the Header port is larger than the exhaust port in the head you have an effective dam.
Damn I do post a lot of stuff over and over here ;)
