Poll question / Pic of spoiler
would this look good on a supra?
  • Yes
    Votes: 3 4.4%
  • No
    Votes: 59 86.8%
  • maybe
    Votes: 6 8.8%
  • Total voters
    68
  • Poll closed .
WA
you are worrying about rice but you are using the stout hood?!?
as for wings, the only ones i like are the 89+, a whale tail, and the imaginary do-luck wing on forza.
suprageezer
778
Southern California
It's all about YOU, if YOU like it go for it, don't worry about what other's say many will be negative just cause they're negative to anything they don't do or their idols don't like it.
If you decide to buy that, get the wings width I'm not sure if it's wide enough. I had trouble finding a wing that I liked and was wide enough to fit a Supra I went with a wing from an old firebird because it was wide enough to make it to the sides of my car.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
A wing i think that would look good on a MKIII that no one that i know of have brought up.
A 90-92 trans am or firebird wing the factory whale tale designed it haves the same square back to the car I tryed to find clear picks but no success its a rare wing but if they made a slighty more agressive set like it for the mkiii i would buy it in a heart beat.
supra_fast
FN Fast
May 13, 2006
128
Calgary, Alberta, Canada
personly i dont think the stout is that ricey. The reason i want it is becasue its functional. there arnt alot of functional hoods out there for the mkiii. or i just cant find many myself.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
If the front of the wing was angle down a tad bit more and if the surface area was a little bit wider it'd be perfect ;).
suprageezer
778
Southern California
EvilEmpire, in that Firebird pic I can't see if that's the Firebird Wing or Spoiler, I used the wing cause it has an aerodynamic shape and is angled down and has a huge amount of surface area, buy the spoiler might fit also since the Firebirds were so wide.
Mk3runner
2,033
Nor Cal
I said no like many others, I like the whole 89+ spoiler look. maybe just maybe if the wing had some more meat to it, it wouldn't look bad.
supra_fast
FN Fast
May 13, 2006
128
im not sure you guys understand what im going for here. i dont actually want the rx8 spoiler. i want the gerneral idea. like a 88 supra wing on those metal braket things.. no lip either. i just want to give it a more aggressive stance, the spoiler i mean. make it look alittle differant but not much. the only think changed is the metal brakets. same height as stock as well.
kaminari and ab-flug are a lot like the regulus, but not as tall or angular, more like the stock wing, just bigger
so called "ricer" wings actually work if you're using them where they're supposed to be... case in point...
*clicky as I don't want to post big picks*
http://i125.photobucket.com/albums/p57/viru52000/TX2K7/100_0228.jpg?t=1181792106
http://i125.photobucket.com/albums/p57/viru52000/TX2K7/100_0227.jpg?t=1181792150
http://i125.photobucket.com/albums/p57/viru52000/TX2K7/100_0226.jpg?t=1181792171
http://i125.photobucket.com/albums/p57/viru52000/TX2K7/100_0225.jpg?t=1181792193
Evilempire1.3JZ-GTE
Jun 22, 2006
1,382
SoCal
You mean MEAT or RICE ? J/K
The TA wing i was refering to looks like a tear drop/whale tail, kind of.
I would do the same design but a little higher off the body and more agressive. but not as agressive as what they did on the next gen TAs(Batmobile looking ones).
Mk3runner
2,033
Nor Cal
meat and rice.... I'm hungry.
