point me in the direction
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
You installing with stock twins or a single/upgraded twins? USDM or JDM harness? Motor from an Aristo or a Supra? R154 or auto?
If the motor is a rear sump, you are going to want to use JZA70 brackets or BIC brackets to bolt it in, if you are using a JDM harness, look into the alternate wire routing method (hole in firewall) and IIRC, all you need to do is wire it up to the fusebox and wire the dash harness. (This is all assuming that the motor is already bolted to their transmission of choice). If you want to take the super easy method then pay Dr. Tweak (search his username here) to do your wiring harness for you (tell him foreverpsycotic from SupraMania sent you). IIRC he charges around 500 to do the full harness conversion including return shipping and he takes about 1 week to do it.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
Yeah...the location of the sump of the oil pan in relation to the rest of the pan. ie. tward the rear = rear sump.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
check my thread :) i explain or at least show most of this
you can tell thats an oil pan upper and lower. the 2jz has a front sump and i have a rear sump from a 1jz sitting there. an mkiv like yours has a mid sump and should work fine as well
whats type of transmission is on it? auto or manual?
thechori
supra-deprived
Oct 3, 2006
567
houston
theciviceater89 said:
manual. i hate auto's. they make me bored while driving, and when you are cruising and 120+mph, you need to be at least a little alert hahaha
well, if you're going that fast you're probably in 5th gear
not doing much shifting
not any different from automatic
:naughty:
