How do these plugs look out of my 2jz to you guys, good bad, all comments welcome, thanks.
Flateric New Member Mar 26, 2008 946 0 0 Calgary, Alberta, Canada Nov 15, 2009 #1 How do these plugs look out of my 2jz to you guys, good bad, all comments welcome, thanks. Attachments IMGP0015.JPG 383.5 KB · Views: 23 IMGP0016.JPG 362.9 KB · Views: 20 IMGP0017.JPG 372.2 KB · Views: 17
Bigzavs 86.5 1JZ Single Turbo Apr 21, 2005 2,267 0 0 41 Arlington, TX Nov 15, 2009 #2 is that a 6 heat range? if so that plug is a lil hot to be running in a JZ, you should change to a 7 heat range plug
tissimo Stock is boring :( Apr 5, 2005 4,238 0 0 42 Melbourne, FL Nov 15, 2009 #3 Is so damn rich its hard to tell. I'd say probably should go next heat range as temps will go up as you lean it out.
