Please Help
ts_MKIII
239
Virginia Beach
ok this is the situation. i have two motors lets call them a and b a=good b =bad
i was doing a motor swap and i was taking motor b out of the car so that i would be able to drop motor a into my car both na 7mges. so here the problem i was trying to pull it out and i noticed the fuel line that is connected to the block was still attached, but i need that line becaseu it connects from the fluel tankn to the motor. so since i did not have use for motor b i cut it on the upper part of the line after the little bolt thing that is connected to the block.(because i could not remove the bolt the held it to the line) now on motor A, it has that little metal thing that leads fuel into the motor already, so i need help trying to take the bolt off of the line from the body of the car, so that i can simply bolt the fuel line in and get set. please help because i cant do it on my own and i need advice on how to take it off.
i hope its not too confusing.
americanjebus
Mr. Evergreen
wa.
havent seen this fuel line bolt thing before, what does it look like is it just a hex head?? is it welded??
so far all that has been established is that you need to remove a bolt from the body of your car.
ts_MKIII
239
Virginia Beach
well how do i take the fuel line from the engine so that i may use it again?? for another engine.. it is hex shaped and i dont knwo if its welded
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
Are you talkin about the fuel union under the intake manifold thats bolted to the aluminium engine mount?If so then take a 17mm socket ( i think) and a long extension and poke the ext down the runners from the top so u have the leverage to turn the socket.Then u have to undo the 10mm bolt that connects the union to the mount.Hope it helps u.
miggles
Jun 3, 2005
526
took me 4 engine removals and squished hand,fingers,bent fuel pipes till i realised there has to be a easier way and after a visit to the auto store i walk away with a appros 50cm extention just bought for that nut.Still when i did the last engine install i managed to pinch my finger on the ratchet attaching it.I was too excited i guess.Good luck with the swap.
