Please Help - Water in Spare Tire Area
benk777
161
Waukesha, WI
So it rained all day, but for some reason I just had to drive the Supra to work. Just now I ran out to the garage to grab something from the car, and notice the garage floor is still really wet. Seems to be coming from the rear of the car. I pop the hatch and lift the carpet, and it's wet. I remove the spare tire, and to my surprise there is over 1" of standing water in the spare well. I soaked it with a towel (many trips) and dried the area.
Question is, is the water coming from a bad seal from the hatch, or from the hole in the tub of my rear driver side fender? I guess I could find out by spraying the car with a hose and seeing if water ends up there again, but I thought that surely someone else has suffered this as well.
Thanks for any advice and/or insight.
Ben
CN: Car sat in rain all day, drove in rain as well. Found 1" of water in spare tire well. Is water coming from seal or hole in fender tub?
benk777
161
Waukesha, WI
simpsons7s;1122217 said:
Usually it is from leaky taillight seals
Funny, because while driving home in the rain my "Taillight Error" dash warning light was coming on and going off. Do I just order taillight seals from Toyota?
Thanks.
Ben
MK-111
Wigan
main culprits for the swimming pool in the trunk are:-
tailgate seal, or the lip it clips onto.
rear light seals.
bolt holes for spoiler.
bolt holes for bottom trim on tailgate glass.
and when you remove the bottom trim, you will see 3 glass supports, water can also get past these.
simpsons7s
Its pronounced Nu-clear..
Oct 9, 2005
253
Riverside, Ca.
Thanks.
Ben
You can get new ones from toyota, or the cheap fix is to get a tube of clear silicone and go to town.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
rear light seals.
You left out rust around the wiper blade. That can hide under the little cover.
But it sounds like your leak is tail light seals. Mine to. There is a drain plug at the bottom of your pool.
DeSloth
220
Australia
I've been through this and it sucks. It took me several months of frustration to finially sort it out. I now own a 100% water-tight '88 supra and it was worth the effort :)
Unfortunately, EVERYTHING in the back of a 20 year old supra leaks. Pull everything out (carpet trims, remove spoiler and wiper) and seal EVERYTHING. I used a lot of sealant and self adhesive rubber. Don't forget all those bolts holding your trim and bumper on - they can leak too. I also replaced the tail-light seals, and sealed the bolt holes on the inside using washers and the above mentioned self-adhesive foam.
Check your work with a garden hose, but leave the traim and carpet out until the next time it rains. There's a 90% chance you will miss something which causes a slow leak. Find this leak, seal and repeat...
Good luck!
Sep 10, 2007
482
Virginia
benk777;1123196 said:
Thanks for the advice. I pulled both plugs for now, and will start with ordering new taillight seals.
Ben
Order them from Jeff Watson at Champion Toyota. Bets prices we can get for OEM stuff. I think both gaskets were $30 when I got them? Not too sure.
Yea, pulling the plugs is a good temporary fix if you need to drive it. I pulled my spare tire too, to let any leaking water flow right out instead of sitting between the rubber and well to eventually start rotting..
