Pitting on block
Oct 11, 2005
3,821
26
Thousand Oaks, CA
Exactly. The pictures are too blurry to tell much. Plastigage those bearings (best done with the valves out, or at least the buckets out) and compare with the TSRM spec. You will know then what needs to be done.
If you have a lube problem the rear bearings will be in much worse shape since the feed is on #1.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
My bad for not being clear on that, I was referring to the tolerances only in the TSRM ;). If you remove the material already built up, it will eat away at the cams and fill right back up, also making the clearances even larger than before.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
quick qestion did you put any thing in you coolent jakest and oil jackets when you were scraping
i have all wasy used greas and used q tip after wors to gett all the shit out of my block
plus makes scarping the block very easy and faster ????
TobyCat
470
Vancouver BC
So, head is back from the machine shop, everything looks good. It is nice and flat (according to them) and I am ready to put my supra back together tomorrow. I gotta borrow a straight edge tomorrow and double check to see if my block is flat.
-ARP Studs
-Stock Toyota head gasket
-machined head
-meticulously cleaned block w/ razor blades and 800grit
-Copper spray
Just a quick question on the copper spray, did I buy the right stuff?
8,897
If your head and block are flat, and you are using an OEM style composite gasket, yes, you bought the wrong stuff. You should have just bought a six pack of beer.
