Piston to head clearance
GJLS
7
OKC
Does anyone know the minium piston to head clearance that can be used on a 7mgte?
Thanks
Jerry
GJLS
7
OKC
Yes the head and block were cleaned up for use with a HKS stopper gasket but the gasket I have is 1mm and the piston is .008 out of the hole and that only gives me .031 clearance so I was a little worried about the piston hitting the head.
grimreaper
2,180
Dallas
where all 6 pistons measured? tolerance stack needs to be taken into account as well. Also any carbon build up down the road could have some serious effects.
I'm sitting right at .045 quench. all six slugs where fly cut to get a uniform .012 deck protrusion. 40cc head combustion chamber and 1.6mm HG. Right at 8.9:1 compression.
whats the head volume after decking?
