Is there a comprehensive comparison anywhere between the different pistons available for the 7M? IE stock, wiseco, JE, ross
I know how they compare as far as compression, but I'm concerned with weight, length of the skirts, and any other differences that might effect their durability and/or the longevity of the motor.
I will put info here as I find it. Please correct/add anything, anywhere you can.
Weight:
Stock pistons.... 366g without
JE................... ~293g depending on bore
Ross................ 357 Grams
Arias(??).......... 310 Grams
Affects bottom ends ability to rev without snapping a rod/excessive wear. Reduction in mass also equates to a little bit of power and efficiency.
Skirt length:
Stock.............. long
Wiseco............ longest of forged
JE.................. short
Affects wear on bores, shorter causing more bore wear, usually not a problem within reasonable mileage.
Material Strength:
JE.................. stronger (21% stronger material than Ross, negated somewhat by having less material)
Ross............... strong
Stock............. stock...
Heat tolerance/expansion:
Forged pistons tolerate more heat in general. Forged pistons (usually?) expand faster than cast/hypereutectic pistons. Faster expansion means you need more piston-to-cylinder clearance (meaning faster wear + more noise, especially when cold. allows more blowby as well)
(hey this post is old but i just noticed a typo.)
Weight:
Skirt length:
Material Strength:
