Pirate air leak (Arrgggggg)
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
Harford County, Maryland
setup: fully rebuilt 7m, t61 turbo, stock 440cc injectors, afpr, walbro, 6 lbs of boost, 2.5" hardpipes, spearco replica, custom intake pipe, external wastegate, open dump tube, 3" back.
Car has been running with a very high idle, did some break in runs and drove it for a bit to try and seat the rings before hunting down the idle issue. Drives great, boosts well (too well, hits fuel cut for various reasons).
Starts up at about 1700 rpms, gradually drops to about 1100ish rpms steady after fully warm. Vacuum is about 14inhg steady at this rpm. No loping or vacuum . When engine is cut off the ISCV tick tocks. Due to the gradual reduced rpms during warmup I think the ISCV works.
Cant set base timing yet as the motor will not idle at 650. Tried to check for vacuum leaks with starter fluid with no luck. Then I plugged all ports into the intake manifold: ISCV, PCV, brake booster line, boost gage line on the back, and the port on the front that supplies a vacuum tree. The damn motor still runs... and actually pretty close to where it should be around 600-700 rpms.
So I have a pirate on board!
My question is what is the best course of action to take next? The leak must be in only a few places:
tb/intake mani gasket, iscv gasket, egr, upper intake to lower, lower intake to head. Like I said I sprayed the shit out of the manifold with no increased idle.... if there can be another pirate air leak location please let me know.
Should I just disassemble the whole intake side and start over piece by piece?
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
I plugged them all at the same time, trying to choke the motor down but it didnt die. The leak is on the manifold itself as I have isolated all hoses and connections outside of the intake manifold out of the picture.
---------- Post added at 03:36 PM ---------- Previous post was at 03:33 PM ----------
only code is code 31 (afm) which is odd becuase it ran fine. I did spray starter fluid into the filter.... i hope i didnt hurt the afm by doing this.
Ian, shouldnt the motor die if I cut all of its air supplies to to cylinders off?
Usually vacuum leaks wont raise the idles 300rpms+ and idle smoothly. More of a lopey.
Try adjusting the cps and see if the idle changes.(with te1 and e1 jumped.)
How are your idle screw and tps set?
7thousandpiecesMGTE
Boostin USA
Apr 9, 2007
469
I can move the cps up and down with t1 and e1 jumped and rpms fluctuate when i do this but it still doesn't get to 650 rpms. The tb screw is not a factor as i have an 89+ tb and its not on there ( I meant to mention that in the first post).
Ian I have thought about the tb blade (I looked and the throttle cable linkage but it is too loose, not tight enough to hold it slightly open, but I will inspect the tb blade itself. And try running it with the AFM unplugged.
I wasnt talking about the air screw but the one on the linkage. That air screw shouldn't be touched with.
Try backing the tps down by hand. That can raise idle as well. If you get it down some you should be able to adjust the rest with the cps.
