Yesterday i'v got a PowerFC i won on yahoo auction befor. Japanese guy said it was removed from old JZA80 turbo. If this true, i can connect it directly to the "stock" wires, just to swap old ECU with PowerFC. But..
If you know, old wires have two connectors for ECU - one small, and big one, that consist of two small and fits with bolt.
So, the pic shows what i've got. There is absolutely different connector on PowerFC.. Probably it's from vvti 2jz, but i haven't the schemes to be sure.
I removed the top hatch of the FC, and found a NEC microprocessor with the sticker "2JZ-GTE". Nothing more. Other sticker outside is "APEXi PFC JZA80 A0021"
And if case it vvti - what's parts i have to replace to make it work? seems like the whole engine head
