Pin Stripe Removal
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Actually the paint should be like new under the pin stripe, The exposed paint should be faded if any thing.. Try to heat it up with a hair dryer or heat gun and get an edge lifted with a razor blade, then use the hair dryer to soften the glue as you go, Then use some rubbing alcohol to remove any leftover glue. then buff the paint out, good luck.. :)
Rajunz
Fast Coonass
Austin, Texas USA
NO man, this is the right way to do it.................I just bought one of the pads ($8.00) and stuck it in a drill. The paint was brighter under the stripes so I just compounded that area by hand and blended it all, pretty easy really.
http://www.mytoolstore.com/astro/astmat06.html
supra90turbo
shaeff is FTMFW!
MA, 01440
YES! The thing that Rajunz is talking about is 3M #07499, "Eraser Wheel". I've used one and I can't believe how good it works.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Yes they work well, but be carefull to not apply to much pressure so it will not create heat and burn through your paint job.. :)
jpeek29208
Boostin Daily
Apr 4, 2005
322
Enterprise, Al
so once i remove it with one of those cool wheels, ill be able to fade the paint in?? Im excited about this, does any local store carry this or is this something that needs to be special ordered?
Chard
62
Fairfax, VA
Has anyone used this eraser pad on a standard drill?
It looks like you need the arbor (attachment) to use it?
bhmsupra
529
It's Not Important Bro
IMO - Power tools and 18+ year old single stage paint is not a good combination for the novice. If you screw up single stage paing, there is no turning back. I suggest you go to www.autogeek.net and search their forums on this topic. It's a great forum for auto detailing and will keep you out of trouble.
IMO - I'd start with a heat gun and work patiently. Ditch the eraser wheel idea. Once the pin stripe is removed go with an orbital buffer, a mild compound and an orange pad to blend the surface and balance the paint fade. Then finish up with a wax or polymer sealant.
Chard
62
Fairfax, VA
I tried the heat gone on one end for about 5 min on it and tried to peel that end with a razor blade but had no success. I really dont want to have a body shop do it for me unless that's the last resort.
supra90turbo
shaeff is FTMFW!
MA, 01440
Holy thread bumpage......
It works on a standard drill. The one we have at work someone cut 3 flat spots in it so it would work better in a 3-jaw chuck..
Chard
62
Fairfax, VA
Sounds good. Do I directly apply the eraser on the pin stripes without applying some sort of adhesive remover on them? Im just skeptical after I tried to remove those pesky stripes with a heat gun and their seems to be to dried up to be lifted up with a razor blade.
Chard
62
Fairfax, VA
anyone?
Rajunz
Fast Coonass
Austin, Texas USA
Just apply directly to the stripes, it just erases them off. It makes alot of dust (just like an eraser). I was worried too about burning the paint, but you would really have to hold it in one spot for a long time to build enough heat, it's nothing like a buffer and compound. It's really easy to do, my wife did it for me and she had no problems removing them, just get a stool and take your time.
Chard
62
Fairfax, VA
Thank you.
Chard
62
Fairfax, VA
Tried using a cordless standard drill with the eraser and it would not remove the pin stripes. Maybe I need a corded drill and put more pressure and take my time to remove the pin stripes.
It actually was scary at first since I thought that I already removed the paint but I just put some rubbing compound and it buff right out.
