I'm looking at adding a couple of things to my '90 ECU, and was curious as to the best strategy for power.
I don't want to overload the fuse to the TCCS, and I'm having some trouble finding power requirements for things. On the other hand, I really want to avoid relying on an otherwise noncritical fuse for the correct operation of my engine electronics.
So what I have are an Apexi AVC-R, an Apexi Neo, and a Zeitronix wideband/EGT/datalogger.
There are 4 places that get +12V at the TCCS. BAT is constant power, so that's out. IGSW gets power directly from the switch (7.5A IGN fuse), +B and +B1 get power through the main EFI relay. (15A EFI fuse) These are in parallel, so it doesn't matter which of these I use, if I do.
Alternately, I could run an ignition power line from somewhere else to things.
The Apexi units are quite particular about their ground requirements (2 wires must be attached to the same ground wire on the ECU wiring harness) but a little less specific about their power requirements, aside from that it be ignition power (As opposed to constant, or accessory power.) The included wiring diagrams seem to indicate that they be connected to +B, but both the AVC-R are of course diagrammed as though they are the only additional units. The Zeitronix wiring diagram doesn't specify if power or ground should be the same as ECU power.
It may be more convenient to use +B1 for one and +B for another unit. The TSRM and TEWD indicate that these are tied together after the EFI main relay, so I can't imagine that it should matter which I use, if either is suitable.
Apexi diagrams want to connect to E1 (Computer ground) instead of E2 (Sensor ground) This makes sense, but so does a good chassis ground. I suppose that using +B and E1 ensures that you get the same voltage references as the TCCS at all times.
Anyway, advise and information appreciated.
