Pic request: R154 (top where the reverse wires are held)
Satan
Tampa
Yeah... I'm a dufus. Was able to disconnect the reverse lights when removing my harness to fix other problems. Now, go to install and realized that I fastened the reverse light wires/connectors, over the top of the tranny. Now I'm reinstalling the harness and I can't get my big-@$$ forearms up far enough to pull it free from that soft, bendy-metal holder. F!
Anyways, pics of the top of the tranny so that I can blindly F that thing up, or maybe some tips to get to it, without removing the driveshaft, droppin' the tranny?
I search already, but need to get back out there to it. Lots of other stuff to get done
THANX!!
j3pz
still learning
when i went to disconnect/connect mine, i traced the wires under the intake mani and then pushed the wire to the other side of the tranny, climbed under, and it was right there next to the exhaust. of course my wires werent in the metal clip, so i dont know if this will work for you
Satan
Tampa
...When I dropped the engine back in, I made sure that all of the wiring was routed properly and fastened. So, I am sure that the metal clip is holding it. I am hoping to see what the direction/orientation is, so that I can try to squeeze a screwdriver far enough to pry it up, releasing the wire.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
You mean like this pic?
