Painting Trim?
lazarous
Walking Dead......
Jun 1, 2005
93
Portland, Oregon
any suggestions on what kind of paint to use? I am sort of on a budget, so I thought that some good high quality spray paint, and some sand paper would do the trick. Any suggestions on brands? I was thinking black trim on a white body would look pretty hot.
JesseH
1,153
Englewood, Ohio, United States
don't use primer....use an adhesive promoter it helps paint stick to fiberglass and plastic a lot better than normal primer, as far as the paint go I painted them with the car
lazarous
Walking Dead......
Jun 1, 2005
93
Portland, Oregon
I was leaning towards krylon for plastics, in the gloss black color. I just didn't want something that was going to eat away the plastic, and/or fade quickly
Jimi87T
1,127
4
Colorado Springs
If it is the newer style trim, the plastic is black. All you have to do is use a "urethane safe" paint stripper to remove the paint. Do not use a standard paint stripper as it can damage the plastic.
This is what I did with mine and I replaced the rubber strip. I think it looks better than painting.
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
get colormatched paint. most chain autoparts stores that have paint section will be able to do it, just bring them a part, or give them the paint code for your car. You can get it in a tin, to use a proper spray gun, or you can get it in a spraybomb. i used a spraybomb, and it turned out ok, but not stellar. i prepped it by sanding, adhesion promotor, wetsand, then paint.
JonoTurbo
Going for broke
CT
I used SEM colorcoat on the trim on my old car and had it on the car for 2 years with no fading.
