My fuel gauge worked fine while it was in the 88 but since I've swapped it into the 87 it hasn't worked. I left the tank from the 87 on so I figured it was just a bad sender. When that tank finally started leaking I put the tank from the 88 on and still no luck. The gauge just sits around a quarter tank wether its full or not. And I'm not a a fan of relying on the warning light.
So I disconnected the sender and the gauge did not drop.
I jumped pin 3 to 4 and the gauge did not raise.
I took the gauge out and did a resistance test on it.
Ig - e 168.9
Ig - u 104.4
U - e 64.8
I know these number aren't spot on, but are thy close enough?
The only thing I can't do rite this minute is test the sender due to the rusted screws that hold it in. I know it worked just fine when I pulled it off the 88 tho. Im stumped, any opinions?
Thanks,
Nick
Ig - e 168.9
Ig - u 104.4
U - e 64.8
Thanks,
Nick
