is there a way to make a 7mgte run in open loop so the ecu doesnt use any of the sensors?
allen600 New Member Aug 6, 2010 166 0 0 oakdale Nov 6, 2010 #1 is there a way to make a 7mgte run in open loop so the ecu doesnt use any of the sensors?
Devin LeBlanc Banned Apr 7, 2010 1,830 0 0 33 Las Vegas NV. Nov 6, 2010 #2 It should when you jumper the two pins in the Check connector to check timing and also engine codes
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Nov 6, 2010 #3 Is this for diagnostics or because you think it will be better?
GrimJack Administrator Dec 31, 1969 12,377 3 38 58 Richmond, BC, Canada idriders.com Nov 6, 2010 #4 No, there is no way to do this. Even in open loop, it still uses the vast majority of the sensors.
jetjock creepy-ass cracka Jul 11, 2005 9,439 1 0 Redacted per Title 18 USC Section 798 Nov 6, 2010 #5 allen600;1636959 said: is there a way to make a 7mgte run in open loop so the ecu doesnt use any of the sensors? Click to expand... Well, it can't use them if they're disconnected. Expect certain problems though...
