OMG!! wiring harness is killing me!
doom26464
Research...research
Saskatoon SK, Canada
ok im having some major trouble with the wiring harness and mabye some one can help me.
1.)I have 3 plugs. behind them is 2 tabs wich any of the 3 plugs slide on too one is in the thermostat housing and the other is under the green plug but that doesn't explain where the 3rd one goes. The colour code as is follow:
the grey plug on the right has a green-yellow wire
the grey middle plug has a red-green wire
and the balck plug on the left is yellow-black wire
*SOLVED* ALL BUT THE BLACK ONE STILL NEED TO FIGURE OUT WHERE IT GOES!
2.)*SOLVED*2 plugs right by the battery that both have 2 wires running to each that are the exact same colour. the wire colour is black-blue and black-white.
3.)2 plugs under the intake mainfold and one sensor(vsv *SOLVED* BUT STILL NEED TO FIND OUT WHERE OTHER 2 PLUGS GO)none of them seem to plug into the sensor.
the grey plug has one black wire and one white wire
the black plug has one blue-yellow wire and one red-rellow wire.
4.) a plug by the starter I couldn't get close enough to see the wiring colour but I can't tell where it goes*SOLVED*???
I know before I took the engine out I should have taken more pics so my mistake. But I know before I took it out there where a few plugs that didn't seem to go anywhere. NONE of the above plugs are the tems(wich my car didn't come with) or a/c(wich I removed) I have located those plugs and tied them up.
IF anyone can help I would be enternaly gratifull!!!
TurboWarrior
Canada
I can tell you the second pic is the electric fans on the radiator. The last pic is not used.
3rd last pic there should be a place to plug in that VSV and its not those. That grey one looks like it plugs in to the ignitor,
1st pic: one of them must go on the temperature sensor. Im not sure why you have so many.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Pic 1.
Two temperature sensors for on the thermostat housing - one is the temp gauge, the other is the temp sensor for the ECU. The black one is your oil pressure lead, goes lower on the block next to the oil filter mount.
WA
have no clue about the wires but...
that is the coolest "supra stick" i have ever seen. maybe those are more common up north. lol.
doom26464
Research...research
GrimJack said:
Pic 1.
ok got the 2 grey ones on but I can't find where the black one goes. I checked around the block next the oil filter and still can't find it. Anyone have any pics??? I will try crawling under the car and see if i can find it there.....
doom26464
Research...research
3p141592654 said:
See attached.
ok I found it but There seems to be no clip on it?? mabye it broke off? Will I need it and what does it do exactly?
EDIT" aftter much searching it seems to be the oil pressure sender. Hmmm i wonder why mine has no clip on it....ITs a jdm engine does that make a difference?
