OMG I need an effin Access Cover for my Fuel Pump! *pics*
RedPhoenix
Kill it with fire!
Sep 23, 2009
222
Tampa, FL
I started to make one... thought I would share...
Its 1/2 x 3/16 steel... cost $1.17 out of the drop pile at the local steel shop.... I cut it into a frame... welded.. grinded..... drilled holes... tapped with a M6x1.00 (typical "10mm" Toyota bolt).... then I had some old street signs which are aluminum.... cut it to shape, drilled some holes....
and then I stopped for the night... I thought the sign would look cool, but it looks ghey with the white/grey paint... so I am going to sand it down (or if I can easily peel off the sign lettering)...
I need to tack the frame into the car and then seam seal the rest of it...
But it should be pretty flush and flat... and then I can get access to my fuel pump when I need it...
ENjoy..
^just sitting there not bolted down so it looks extra worse.
Smashey
88
Grande Prairie
Thats pretty sweet. Im going to be changing my fuel pump soon but will just drop the tank, but still very interesting idea.
Sent from my GT-I9000M using Tapatalk
RedPhoenix
Kill it with fire!
Sep 23, 2009
222
Tampa, FL
yeah the tank isnt bad to drop but I do plan on going even further with my fuel system to run ethanol and a surge tank.... and its gonna be some trial and error to make it perfect so dropping the tank each time will suck.
8,900
I used to work on the line at Toyota. Then I went to an Audi dealer, and back to Toyota. I never had a problem getting to a fuel pump. Raise the car, lower the tank. I understand your fustration of working in the garage at the house as I have been doing it for 7 years now.
