Ok i bought a holset
JStoked
646
Edmond, Oklahoma, United States
Ok i just bought a holset hx-35. I have read the post on it And i am lost i know nothing about waste gates and how they work. So my ? is with all my mods i already have what else will i need for this set up? and how does an external waste gate work? i know this is prob a stupid question but i am just trying to learn.
my mods
550 injectors
Lexus maf
apexi neo
aem true boost
1jv coils
huge ic with 2.5 ic piping ( 4" inlet and outlet on the ic)
motor bored 40 over with probe pistons
clevet bearings (really ndc)
upgraded oil pump line from grimsta
upgraded oil pump
255 walbero pump
drilled out j-tube (this is temp tell i get a afpr from dm)
So what else will i need and wiil the hx-35 work for me?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You'll need a t3 or t4 tubular manifold for that engine and a 38mm (minimum) external gate to control the turbo. External gates work off of a remote pressure source (compressor housing or IC pipe) which in turns open up a fairly large valve to dump exhaust to atmosphere. When the exhaust is dumped, the exhaust pressure is reduced to the turbine and thus the turbine slows. A slowing turbine creates less boost pressure.
Hope this helps. :)
