Oil thickness..?
David D
53
Califfornia
My 7mgte has excessive oil blow by, and is consumming the engines oil at a rapid pace of a about a quart every week and a half... Im considering running a thicker oil to hopfully subdue the problem for the time being. Currently I am running 10w-40 and I would like to switch to something thicker to help the problem. My question is how thick can I safely go? Would 20w-50 be ok to use?
any insight would be helpfull thanks again.
jetjock
creepy-ass cracka
9,439
No problem. People run 20-50 on healthy engines all the time. Not very oil savvy but neither is the engine going to explode. I just hope your next smog test isn't soon. Not only because of the oil but because your cat is very likely dead by now...
solpower
Albemarle, nc
im running 20-50 with lucas oil additive lol its just a patch until i can fully rebuild everything soon. but it still runs fine just before you drive it let it sit for a few so that sap were calling oil can actually get to all the parts.
shiftysupra
180
Tucson, AZ
you would never put lucas in your engine again after you see what it does... personally i dont think frothing up your oil is a good thing. hopefully you get the problem fixed
mkiii222
Troy, MI
I've run both AmSoil 20w50 and Castrol GTX 20w50(depending on financials when I hit 6k) for a few years now and it does fine. Like said above, just let it run for a minute before taking off. Consumption fell from 1 quart every 600 miles to 1 quart every oil change.
Next change I'm gonna try some 10w30 and see how she does now that 90% of her problems are fixed (still need to get around to swapping out the valve stems so I still plan on some oil usage, but the leaks/drips are all patched).
mkiii222
Troy, MI
Doward;1266071 said:
Castrol to 6k, I can see - but why are you changing Amsoil 20w50 so often?
Never got back to this thread, but the Castrol would be 6k, the Amsoil would be yearly/12-15k.
