Started leaking and dripping alot of oil. determined the oil pump drive is leaking at the front cover. There's alot of play in and out which seems to be the cause (see video).
http://www.youtube.com/watch?v=ZQ9n5Noggzo
Do I really have to pop the head to get that cover off ? it has MHG with studs and if I do have to remove the head can I get away with just loosening the studs and lifting the head enough to get the cover off and then on ?
I really don't want to pull the engine to get this done.....
