oil pressure
ma70t
7mgte-s
Jun 7, 2005
141
va
would a blown turbo cause low oil pressure ?????
i mean blown oil seal on the turbo itself
MKIIINA
Destroyer of Turbos
Plano, TX
yes if your really low on oil. get your shit fixed. you motor wont like sucking down shredded turbine blades....
jdub
Feb 10, 2006
10,730
Valley of the Sun
Not likely to significantly affect pressure...the turbo feed is between the #4 & #5 oil squirters inside the block. It goes from the turbo straight to the pan. The feed to the main and rod bearings (primary determiner of pressure) is at the front of the motor. What will happen is you will lose oil quanity...if you have a blown seal, the biggest danger is running low on oil and trashing a bearing (can you say rod knock?).
MKIIINA is right...you need to get it fixed.
