Oil Pressure Issues
Obsessionw/Boost
198
Albany, NY
My oil pressure gauge wasn't working for quite a while so I never knew what my oil pressure was. Now I fixed it and it's getting me worried. What should my oil pressure be for a completely stock 7M.
Stock turbo, Stock piping, Stock IC, Stock fuel injectors.
Nothing has been tampered with.
Frank Rizzo
478
Fixing your girl's car
I agree, when oil temps are above 190 F, oil pressure should be halfway inbetween the 20 psi mark and the 0 mark. At WOT above 3K rpm should be just under 40psi, like 38.
When oil temps are cold, it will hang around 40 at idle and while driving. Don't hammer it till the pressure comes down at idle aka when the oil is up to normal temp.
mkIIIman089
Ohio
^ For the stock gage that sounds relatively accurate. If you have an aftermarket though, you'll see whats really going on.
