Oil pressure gauge stopped reading
IndigoMKII
2,181
Madison, Virginia
Make sure the single wire didn't slide off it's clip, mine has done it before on my 7m. It scared me pretty bad to watch my oil psi go from great to none, my eyes were like:cry:
ryan625
60
Lynnwood
S.A. supra;1895045 said:
Did it ever work?
Not since I have owned it. Previous owner said it had recently stopped.
Mind you I have only put about 3000 miles on my supra so far. I'm trying to fix everything the previous owner "fix" or "installed"
scottiedawg66
Bay Area Ca
10 years later I am still doing the same thing. welcome to owning a mk3!
S.A. supra
2,405
Buda, Texas
Driftmotion sells a little line that comes off the block, to get it out from in back of the a/c compressor. Then connect the old 7m pressure sensors. Look for the oil pressure wire under the intake manifold and connect it. You should be good to go.
