Read in the oil education area about 10lbs/1K rpm is a good rule of thumb. Was running 10/30 castrol and it's ~5lbs on gauge at idle. It can idle like that, perfect idle, no valve noise at all. The most I can get is 25 psi according to the gauge.
Switched to 5/20 castrol and same results.
I would expect some valve noise but none and there's oil up there....leave the cap off and there's oil in there moving. Has new oil pressure sensor.
Are all these stock gauges (boost, oil, temp) just that inaccurate ?
What kind of variance are we looking at ?
