Oil Pressure, Compressor Surge
FatalStylez
144
Rolla, Missouri
I have a question about both, Whats normal oil pressure in an 89 Supra Turbo, at idle? at Cruising speed?
And Compressor surge. I have it in my supra and how do I fix it? The car has an Aftermarket Blitz BOV
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
I've had quite a few friends have surge, and every time it ends up being the line to the bov.
make sure its a BIG hose, not some tiny one thats being crammed on there, and try to make sure its a dedicated line just for the BOV.
shimmed (5mm) pump oil readings:
cold - 40-60psi (depends on temp)
hot - 10psi (on a fresh start)
normal driving - 20-40psi most of the time
i've never watched my oil pressure when im racing or driving fast, so i dont know about that, but, if you start your car, see where the oil pressure is at, and then you watch the car warm up, you can see the pressure drop as it gets warmer.
tissimo
Stock is boring :(
Melbourne, FL
Stock gauge
1/2 way between the first mark and 0 at idle warm,
it reaches 40 psi by 2200-2400 rpms and stays about there
5w-30 oil.
my stock 170k miles 7m.
dumbo
1,911
Albera, Too Far North
FatalStylez;1217184 said:
k mine has abuot 100k miles and it idles at around 25-30 warm
and 40 driving
And the line to the BOV is about the thickness of a pencil.
i wouldn't worry about you oil then,
where are you getting vacum for the bov and if you pull it off when idling is it getting vacum?
FatalStylez
144
Rolla, Missouri
Too Dark to look right now. I will Look Tomorrow after class. it surges at lower boost, and lately at higher boost. So im tryin to stay out of it as much as possible.
