oil pan leak repair question
91supra7m
4
Wisconsin
to anyone who's had a leaky oil pan what'd you fix it with? new gasket, toyota gasket maker, rtv or what? Also did you pull motor or drop front end or what?
thanks
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
FIPG, the cork gaskets suck. You can get the pan out if you lift the engine with a hoist. I'm not saying I would recommend it, I'm just saying it can be done.
use fipg from Toyota. easiest bet would be to just remove the connections from the ecu(for the harness), remove the fan/clutch/radiator/power steering/ a/c, unbolt the trans member, unbolt the engine mounts and brackets and remove engine. reseal and re-install engine. should only take about 1-2 hours to remove and same for install and a hell of a lot less to remove than dropping the sub frame.
pln
Get the gate!
Apr 10, 2007
107
eskilstuna.SWEDEN
Its up to you really. Transmissionbolt are really timetaking. I hate them. Allso you have to line up the enginge to get it the splines in when re-installing. and then you have all this "remove the fan/clutch/radiator/power steering/ a/c,"
1-2 hours.. for all this??
I belive that when I see it.
mkiiSupraMan18
Needs a new username...
United States
^ I believe he was saying to pull the engine/trans together... 2 hours isn't a stretch at all. If you suck and/or have never done it, it might take you three. :icon_bigg
To be fair, he did forget about the fuel lines,clutch slave, speedo cable,drive shaft, and taking out the shifter/radiosurround from inside the car... actually, quite a few steps were forgotten... Heater hoses, ground wires, heater control plug from the harness, the harness for the alarm horn... brake booster vac line, throttle/cruise cable, oil cooler lines... and thats just off the top of my head.
