Oil on timing belt
mk3turbo
176
4
michigan
When I bought my supra, there were oil on the timing belt. So I redid on timing belt with new main oil seal, rear oil seal, oil pump seal, pretty much all the seals and gaskets. Put it all back together and still had oil on the timing belt like before. What could it be? Im gonna rebuild my engine soon so just looking for some advice on that oil leak on the timing belt.
mk3turbo
176
4
michigan
whitemike;1582427 said:
Did you replace the gaskets behind the lower timing cover?
The gasket between the block and the timing cover? The timing cover that you have to resurface with the block if you are doing a rebuild right?
