oil leak question
SupraNBama
Anniston,Alabama
ok i just recently got my supra back this sunday and drove it around a little to get some miles on the new clutch and looked under the car and noticed oil was leaking...well i popped the head and looked inside and couldnt see nething and then when i looked back behind the alternator oil was coming from the vent tube behind it. At first i thought it was just the hose leaking so i replaced it...still leaking....i see that the tube can be removed is it hard? or is there a easier way to fix this than having to take my alternator out and yanking on the tube to get it out? any help would be appreciated.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
I believe it is pressed into the block. I (me) would first try cleaning all around the outside with steel brushes and carb spray. Then I would use brake spray (leaves no residue) all around. Then I would apply some sealant, like permatex, around where the tube goes into the block.
Before all that, I would make sure my vent tubes and passages were all clean. The ones from the valve covers into the throttlebody/intake. If they are clogged, it will create back pressure in the engine and cause leaks at the tube in question.
SupraNBama
Anniston,Alabama
well i got down there yesterday cleaned it off and changed the hose itsself...guess it was the hose i was using but its not leaking there now...just got one other leak to fix...the dreaded oil pan gasket
