oil in the intake and IC lines...
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I havnt looked much into the 60-1 upgrade, approx how much hp can it produce with all the appropriate upgrades (exhaust, and fuel mainly), how many psi can you push them to safely.. you know.. the basics.
oh and is the 60-1 the CT26 upgrade or is it a whole different direct bolt turbo?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
sathu, Horsepowerfreaks carries the SP61 and SP58 in a bolt on configuration. Plus there are many upgrades you can do to the CT26.
hottscennessey, there is a thread that deals with this in the FAQ section: http://www.supramania.com/forums/showthread.php?t=3329
americanjebus, sounds like valve stem seals all right. This is not a terribly complicated thing to fix with the head in the car, there is an article about the procedure over at SOGI if I recall.
Link: http://www.supras.com/04/techcenter/display.php?QID=5
Sorry, my turbo rebuilding knowledge is limited at best.
PCV = Positive Crankcase Ventilation system. It allows pressure in your valve covers and crankcase to vent into your intake, and from there into your engine where any offending gasses are burned.
