Oil in my 3000 pipe
SupraStorm1080
IT'S A LIVE!!!
Apr 19, 2006
78
riverside, SO cal
Hey guys,
Today i was driving my car around and after i was done i thought i should finally retorque my engine head after putting it back on a little while back. When i was taking out all the stuff i found some oil in my ic pipes leading to the 3000 pipe,oil in the 3000 pipe and some oil in the hose leading from the 3000 pipe to the blow off valve. This got me concerned because i was thinking maybe oil is leaking out of the turbo or the intercooler but i have no idea. :3d_frown:
Do you guys have any suggestions?
Thank you
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
If there was a small amount that is perfectly fine. Your PCV hose is routed to the intake pipe, which in turn sucks air through into the turbo and then puts that oil in your lines. It's normal to have this happen and you have nothing to worry about.
