Oil drain flange???
Gritz
155
nc
Does the 1jz use a stanard oil drain flange..it looks to be a little longer im just not sure...
Gritz
155
nc
annoyingrob;1150255 said:
Huh?
What oil drain flange?
The flange thats on the oil pan..im going single..so i have to get rid of the y pipe oil drain....Theres some on ebay for cheap, just not sure if those will work on the 1jz oil pan...
Gritz
155
nc
Blind Drifter;1150270 said:
I used a drain from a T4 turbo and used it on the pan....
Well if that the case then the ebay ones should work...
Gritz
155
nc
annoyingrob;1151190 said:
In that case, the drain flanges on standard Garrett turbochargers bolt right on to the oil pan.
Cheaper solution...great!!!
