Oil Cooler
Status
Not open for further replies.
ians13
537
Jacksonville, fl
Has any one Installed a after market oil cooler, on there ride you can get a oil cooler with a fan for under 200$ i think this will be a good mod for keeping the motor cool, but it does not seem like a lot of people do this, why?. will the oi pressure drop to low if a bigger oil cooler is installed. "cooler oil = better oil pressure cooler engine." More HP
antman
632
TN
lots of guys do this. theres quite a few here. i don't think you'll need a fan though..
C
cnewingham
Guest
you dont need the fan. Just get an average 8 X 11 X 1.5 cooler with good hoses, oil filter relocation kit and thermostat and you will be good to go. I used the aeromotive socketless -an hose with there fittings. Total was:
$70 cooler
$95 relocation kit
$150 socketless hose and fittings
$60 thermostat
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
you do know the stock set has oil bye pass all ready so there is really no need for a oil t state in less you just wasteing money on point less things
like mega coolers that take up the front of your car ect
for me i use a B&M trans cooler with the stock bypass new lines ran an fittigns as well to stock locations
this is over kill for the type of racing i do but what ever
any thign bigger then that is oval track racer
C
cnewingham
Guest
you do realize that the stock by pass doesnt flow oil to the cooler by temp but by psi (around 40 iiirc) where as with my setup my oil runs at close to the same temp and flows more oil than yours so I dont feeel any money is wasted. Do a little more research before giving not so correct advise. However I will agree that maybe it is over kill for normal dd driving but it is added insurance plus if I have the money to better my oil system then why not?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i said by pass i know what i said and all say it again
it will by pass eghough oil for it to be in the proper temp zone easy
as for oil flow it depends on your oil pump and if you decide to run the na oil filter monte
so don't be putting my shit down
simple stuff is great cause it's simple and works well and if it fails simple to fix
bigaaron
4,692
Pomona, CA
www.driftmotion.com
No nash, cnewingham is right. When you relocate the fliter, you remove the filter housing, and you need an external thermostat in that case. The stock cooler is ok for a stock horsepower daily driver, not for a 400whp car driven hard. The stock oil cooler is wimpy, and the stock filter location makes it a messy pain in the ass to do oil changes. Why talk someone out of a oil cooler upgrade?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I was wondering, has anyone done the relocation, and thermostat with a stock oil cooler, or dual stockers?
If not why, is that setup not efficient, or does it now flow enough?
supra90turbo
shaeff is FTMFW!
MA, 01440
Pressure diverted oil to a cooler is stupid.
Oil makes pressure easier when it's cold, so what sense does that make?
Temp controlled bypass is the only way to go.
C
cnewingham
Guest
Not trying to be an a$$ but again I stand firm on what I posted and obviously so does everyone else.
As far as putting your shit down, take it how you want cause I really dont care but dont miss guide people on things that you are not that familiar with so dont be afraid to use the search button to do a little more research before giving others advise.
ians13
537
Jacksonville, fl
damn all this hostility, am not missing with any filter relocation and stuff I just think a better oil cooler might help with engine temps I know that a fan on it may not be necessary but at such a great price why not I can just wire it in with the stock ac fan. off a relay of course, so when the ac is on in the summer my oil will get cooled even better.
sounds good to me.
C
cnewingham
Guest
no hostility. I just want you to make your decision with the correct facts and parts that you need to do it right.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
this was blown over the setup i sujested works fine cheep less to worrie about aka leak's /failed oil t stat sean it befor as well
yours is over kill witch every one likes to do i don't hate your setup or hacking it
that's about it
ps water is the main thing in warimng up a car and temp
can we all be friends now
ps i can not fully make full huge seantce and such cause no one under stands when i type so i give you jist of what what i mena and that is it
plus think of it as cold water tap and hot water tap as int eh stock bye pass wheil you drive
Status
