oil cooler on an n/a
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
hey all, i was wondering is it possible to put an oil cooler on an n/a. i thought it would be a good idea cause i thought it would/might help cool the engine a bit. and if so, how would you hook it up to an n/a block? and would there be any problems???
Yes you can do it (NA's bound for hot climates had a version of the horrible GTE pressure based system installed stock)
Have a look at the GTE section there a few good write ups on how to do a full flow T Stat based system.
