oil cooler line length
dansmith11
61
calgary
anyone running an aftermarket full flow oil cooler setup mind telling me how long your lines are and where you mounted the cooler?
my plan was to keep the oil filter in the stock location and run the cooler lines off a sandwich plate.
supraman7mgte
Shut up,bitch!!
Sunny California
I plan on replacing the stock pressure release valve type system with a temp controlled one. all i have is a remote mounted oil filter that hold about an additional quart,mounted where the passenger side front tow hook is.
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
on my old 1JZ, I mounted mine in front of the a/c condenser and custom brackets. I bought 6 ft. of -10 steel braided hose, but IIRC I used more than 6 ft. (had some extra from another project).
I used 1 oil cooler, 1 oil filter relo.
dansmith11
61
calgary
6ft total i assume? so like 3 ft from the sandwich plate to the cooler, and another 3 ft back?
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
6 ft. total. I ran from the oil relo adapter (engine side) to the oil relo adapter (filter side), to the oil cooler, out of the oil cooler back into the oil relo adapter (engine side)
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
which relocation kit/ cooler kits did you guys use? ebay bad or ok? the one i looked at "said" it outperferformed the greddy and it was tested on a twin turbo supra?
any more info on that temp controlled system?
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
for the love of supras go to summitracing.com! all can be found there. If one of their oil coolers will cool a 302CI V8 spinning to 7k rpm, it will easily handle a 500hp supra!
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
Hey Dan...just did one on my supra
I put it in front of the rad in the front nose with the intercooler..the lines are about 4 ft, a bit long, but gives extra room to tuck them around the frame and into the nose neatly and have some slack
