So I have been tossing around the idea of running a remote oil filter. That is not in question but what is, is should i run it through a cooler right off of the remote filter and ditch the factory oil cooling lines and fittings all together.
I am not sure of the distance that the oil will have to go through the filter and the cooler at the same time is going to be ok. It seems to me it will cool better because all of the oil is going through it but might be a problem with the flow rate or the pressure
Any ideas, thought, help, comments would be greatly appreciated!
