Hello everyone. I took the car out for a drive and drove it a little bit hard, pretty much stepped on it all the way to 5k rpm through 2nd and 3rd. Once i got back home i opened the hood and noticed there was a bunch of oil spilled all over the abs housing on the turbo side. I looked at my dipstick and noticed it sticking out about an inch. Now i am assuming that the oil came out of the dipstick as i did not see any other signs of oil spilling out.
My mods are:
Built motor. JE .020 pistons, with JE rings
stock rods
cometic 2.0 MHG
Fully balanced bottom end
ARP studs
new bearings, water pump, oil pump
Complete stock rebuild on the head.
I have the stock PCV system setup.(Not Modified)
What could be causing this problem? any help would be greatly appreciated. thanks in advance.
My mods are:
stock rods
cometic 2.0 MHG
ARP studs
