Oil Catch Can Needed?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
I tried seaching this but the words oil and can were too short to return results so here goes:
Is the basic purpose of a catch can to separate particulates and sludge/impurities from oil? Can someone give me a basic overview on installation and operation, and would installing one on a NA be healthy for it?
97TSiAWD
In need of more traction
Jul 18, 2006
124
Michigan
A catch can doesn't act as a filter; it is simply a collector for oil that gets vented from the valve covers (due to a build up of pressure). The main purpose of the catch can is to prevent oil from going back into the intake where it can collect and coat the intake pipe, IC pipes, intercooler, and intake manifold.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
An oil catch can is designed to 'catch' the blow by off of the two top nipples on the cam covers (they then run into the throttle body and accordian hose of the turbo, or the equivilant of that in your case)
The blow by generally cause power robbing carbon deposits into the intake manifold and oil buildup in the intercooler and piping (for turbo cars of course) You should also see some benefits from this in your NA supra.
To instal a catch can, it must be mounted under the hood on the cold side of the engine (intake side, the can must have an air filter on top of it to better help the oil vapors to condense into the can) The oil vapors must cool down to condense into oil, thus it should be mounted on the cold side (I've seen some mounted where the battery was and by the brake booster and clutch master cylinder). I would Tee the two nipples on the valve cover into one line and run it back to the catch can inlet. The outlet line should run to wherever the stock lines went to on your NA supra (for turbos this is the accordian hose) I would also cap off the vacume line that was conected to the stock lines on the throttle body.
Viola! A working catch can! Just make sure to check on it every now and then to empty it.
The catch can does not separate particulates and sludge/impuriies from the oil, that's the oil filter, the catch can 'catches' most of the oil vapors and any impurities associated in the vapors. I hope this helps you out :).
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Damn! You beat me by one minute! Eh oh well...
