Oh Oh Code 31
666theboy
BEAST
May 4, 2008
wales
:1zhelp: In the mornings i have to let my car warm up for about 3 or 4 mins before i drive off as otherwise she runs slightly lumpy until completely warm (about 10 mins).As i slow down the revs drop to near stall (300ish)then pick back up to normal, but a couple of times it has actually stalled and its auto. I pulled my codes and it says code 31,which is an open or short circuit in air flow meter signal.I have recently fitted a K&N high flow air filter, could it be because of this? Does anyone have a remedy to this or do i have to get a new meter?
Or would having it tuned do any good? I have also fitted a straight through back box as well if that helps. Thanks for any help you can give me on this.
All of the work done on this car has been with a very tight budget (2 young kids) and free labour (me and my cousin Martin)
:icon_evil:icon_evil:icon_evil
Cycoclown
SHAAWING!!!
Jan 18, 2008
131
Vacaville, CA
mmm i had this problem with mine, i also own an auto. i switched over the electronics from another AFM and it works fine.
When i noticed this problem i found out i had several studs missing on the exhaust mani side of the head. might want to check that too..
supramk3man
414
kentucky
Check yours wires, when you put in the k&n you might have moved the afm to much and caused a wire to break or to be come out of the plug alittle.
666theboy
BEAST
May 4, 2008
wales
cheers mate i`ll check in the morning as its dark over here at the moment
20:26
:icon_bigg
supramk3man
414
kentucky
hard to think of it be being dark at 3:45 p.m. here, oh how small the world is sometimes. Good luck on the repair
8,900
Visually inspect the plug and harness to make sure it looks ok.
It isnt easy to ruin an airflow meter, unless it has outside help. Over oiled K&N, dropping, etc.
