Octane in relation to gas mileage
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
I had read somewhere that the lower the octane, the better your gas mileage will be. I know that this is a pretty uneducation assumption, so I wanted to know whether this was true or not.
-Matt
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
-Matt
higher octane is more efficient
da89soup
World I Am Gay Blue!!!
Dec 2, 2005
1,978
Fargo ND
Yes and no!!! I belive the cutoff is 9:3:1. If your engine compression is higher than this your car will most likely run more efficiently with 90+. but if your compression is less than 87 octain is more efficient.
Soup
:ugh2:
GotTurbos?
Apr 24, 2006
951
Dallas, TX
Soup
:ugh2:
I didnt know that :) Thanks!
8,897
The number on US gas pumps represenst resistance to detonation. Efficency as you are thinking is not a factor.
There is not more BTU's in 93 vs 87.
jester1341
topless and blown
Western Maryland
isn't forced induction a factor as well.... like SCed and T'd vehicles are to use higher octan ratings to prevent knocking[pre-detonation]
i remember a thread somewhere before[maybe a different board]
as da89soup said high compression engines would recomend it to ward off knocking.....using FI we are 'low compression' but also are adding extra compression other engine don't have
am i at all on point here??...do we have anyone with PHd in fluid dynamics...;)
john
dbsupra90
toonar
indiucky
john
yep its called effective compression ratio. base compression ratio + psi boost = effective compression. higher the boost, the higher the ecr. thats why oftentimes there is a reference to safe boost level on pump gas and running big boost requires higher octane fuel.
