OBX or pacesetter header question O2
RIPDOTCOM
157
Tallahassee, FL
I see a lot of these headers on ebay and want to order one but it looks as though the O2 sensor bung is too far back for the stock O2 sensor to reach. Can someone enlighten me on this? Also, where do the headers mate to? Do they go all the way back to the cat?
MKIIIChucky
101
south jerzy
the down pipe should go to the cat ! plus if the o2 sensor wire is too short just cut it n splice in a 16gauge wire to extend how far u need it to go !!! was going to do the same thig but im going with turbo now !! Good luck wth the N/A
90T04
Tucson, AZ
www.azsupras.com
Hi, I had the Pacesetter header on my 87NA years ago. You are correct, the o2 sensor is relocated waaay down right before the second cat. In my opinion this is too far away for proper operation.
I am not sure about your car, but my 87's o2 sensor was non heated, (only 1 wire. I think later models were heated) o2 sensors have to be HOT to even work, so being that far down may decrease its performance. Not to mention that you have to splice in 4 feet of new wire.
here is a link to a webpage where I described my thoughts on the header back when I got it in like 2000 or something.
http://members.cox.net/7mgte/header.html
hope this helps
Ryan
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
I have an '89 N/A, and am considering the OBX headers, as they appear to be better built, and stainless. The 02 mount "is" too far back. Also, it appears that the downpipe is too long to just mount it all up to the cat.
I will cut the downpipe right after the "Y" (goes to headers), and cut off the cat mount flange. Then flip the pipe around so the 02 mount is up front, weld it onto my new Magnaflow cat, and the "Y" connector. :biglaugh:
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
Before i got my turbo, i had an 86.5 NA, with pacesetters. The o2 sensor is way off, but running a wire to it solves it, any muffler shop will do it.
