o2 sensor wiring. need help connecting colors
str8_6
master yuepeng
Mar 14, 2007
241
wa
So the 1jz i'm messing with has 1 blue and 2 black wires for the oxygen sensor, no connector. The colors for the o2 sensor connector (wiring harness side) has a red, white, and black wire.
Which wire goes where? I'm sure the two black wires can interchange, more concern where the blue one goes. Thanks
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Red-blue wire is heater positive (to one of the black wires).
Black-red wire is heater ground (to the other black wire).
White is sensor signal (to the blue wire).
Jeff
str8_6
master yuepeng
Mar 14, 2007
241
wa
Thank you sir. I didn't want to assume that, but figure it would be considering it was the top wire out of the triangle plug.
