o2 Sensor Rewire
N
NDBoost
Guest
Whos done them and what are the options? My Sensor wire broke on the engine harness side of the o2 sensor system. Problem is it broke right at the connector so i cant really rewire it. Ontop of that the connector is broken and brittle. Ive searched SF & SM a bit and didnt find anything..
Need to know if possible & where to get a new OEM connector, how to wire it up again etc etc.
or i need to know my other options as far as o2 sensors go.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
This is a good time to take full advantage of your situation.
Buy a few o2 sensors that MDCMotorsports is selling (that was mdc, right?), find the appropriate mating connector and graft this into your factory wiring harness. Either that, or find a suitable "universal" 3-wire o2 at a parts store that will work, find out what it fits, then rob the connector from that particular car in the junkyard. Done and done.
N
NDBoost
Guest
well my o2 sensor works and i know it because when its hooked up i dont run really rich, but when its not .. i do seeing as i dont have $30-$50 for an o2 sensor ..
i just wish there was a local place here in arizona that stocked these things i cant wait a week for em to ship!
csr ma71
rooftop sniper
Apr 2, 2005
254
bay area
www.angelfire.com
I hardwired my o2 sensor at the harness with some butt plugs because it was real brittle and you can see the copper wires. I feel like I should have done this years ago. My torque has gone up like crazy. My gas mileage still sucks, but there's no longer that little delay between hiting the throttle and actually moving.
supra90turbo
shaeff is FTMFW!
33
MA, 01440
"butt plugs"?
i think you mean butt connectors. if you're using butt plugs, well... i just dont know
LoveMy7MGTE
162
Grosse Pointe, Michigan
somewhat offtopic, but what would you reccomend for a replacement cps conector? also, the wire colors are diff on the cps than the harness. on my cps i have a blue, green, yellow, and white (actualy 3 white but im assuming all3 white go together) damn i hate electrical
